Ok, so here is the testbench code for tdc_decode (unfortunately I DONT HAVE THE SOURCE CODE)
architecture beh of tb_tdc_decode is
component tdc_decode
port (reset_n_i : in std_logic; -- asynch reset
clk_128meg_i : in std_logic; -- 128 meg system clock
enable_i : in std_logic; -- enable signal
tdc_i : in std_logic_vector(63 downto 0); -- tdc data
rise_o : out std_logic_vector(5 downto 0); -- value for rise
rise_fall_o : out std_logic_vector(6 downto 0)); -- rise - fall value
end component;
--constant definition:
constant clk_128meg_i_period : time := 10 ns;
-- signal definition:
signal reset_n_i : std_logic := '0';
signal clk_128meg_i : std_logic := '0';
signal rise_o : std_logic_vector(5 downto 0) := (others => '0');
signal rise_fall_o : std_logic_vector(6 downto 0) := (others => '0');
begin
--UUT Instance:
uut: tdc_decode
port map (reset_n_i => reset_n_i,
clk_128meg_i => clk_128meg_i,
enable_i => enable_i,
tdc_i => tdc_i,
rise_o => rise_o,
rise_fall_o => rise_fall_o
--clock generation:
p_clock_gen :process
begin
clk_128meg_i <= '0';
wait for clk_128meg_i_period/2;
clk_128meg_i <= '1';
end process;
--stimulus:
stim_proc: process
begin
wait for 10 ns;
reset_n_i <= '1';
wait for 15 ns;
enable_i <= '1';
tdc_i <= "0000111111111111111111111000000001111111111111100000000111111000";
wait for 1 ms;
reset_n_i <= '0';
wait for 1 ms;
reset_n_i <= '1';
wait for 1 ms;
enable_i <= '0';
wait for 1 ms;
enable_i <= '1';
wait for 1 ms;
assert False report "End simulation!" severity Failure;
end process;
p_check_tdc_out: process(reset_n_i, clk_128meg_i)
variable tdc_vec_v : std_logic_vector(63 downto 0) := (others => '0');
variable tdc_newvec_v : std_logic_vector(63 downto 0) := (others => '0');
......................................................... (Sorry I don't have space to post the entire code but its not important)
end process;
p_check_tdcmodule: process(clk_128meg_i)
begin
if (clk_128meg_i'event and clk_128meg_i = '0') then
assert rise_o = std_logic_vector(to_unsigned(tdc_rise_s, 6)) report "Wrong output: Rise time is not calculated properly" severity error;
assert rise_fall_o = tdc_rise_fall_s report "Wrong output : Rise time - fall time is not calculated properly" severity error;
end if;
end process;
end beh;
And this is the tdc_readout source code:
entity tdc_readout is
tdc_i : in std_logic_vector(63 downto 0); --tdc data
scale_i : in std_logic_vector(7 downto 0); --scaling value from spi reg
rise_fall_o : out std_logic_vector(6 downto 0); --calculated rise fall value to spi
phi_frac_o : out std_logic_vector(13 downto 0)); --phi fractional value to add3
end tdc_readout;
architecture rtl of tdc_readout is
signal rise_s : std_logic_vector(5 downto 0);
signal result_s : std_logic_vector(13 downto 0);
signal phi_frac_s : std_logic_vector(15 downto 0);
signal tdc_reg_s : std_logic_vector(63 downto 0);
constant operand_c : std_logic_vector(15 downto 0) := "0100000000000000";
component tdc_decode is
port (reset_n_i : in std_logic; --asynch reset
clk_128meg_i : in std_logic; --128 meg system clock
end component;
component mult_6t8 is
rise_i : in std_logic_vector(5 downto 0);
result_o : out std_logic_vector(13 downto 0));
end component;
begin
i_tdc_decode : tdc_decode
port map (reset_n_i => reset_n_i, -- reset from pad
clk_128meg_i => clk_128meg_i, -- system clock
tdc_i => tdc_reg_s,
rise_o => rise_s,
rise_fall_o => rise_fall_o);
i_mult: mult_6t8
rise_i => rise_s,
scale_i => scale_i,
result_o => result_s);
p_reg_tdc: process(reset_n_i, clk_128meg_i)
begin
if(reset_n_i = '0') then
tdc_reg_s <= (others => '0');
elsif(clk_128meg_i'event and clk_128meg_i = '1') then
if(enable_i = '1') then
tdc_reg_s <= tdc_i;
else
end if;
end if;
end process;
p_phi_frac: process(reset_n_i, clk_128meg_i)
begin
phi_frac_s <= (others => '0');
phi_frac_s <= std_logic_vector(unsigned(operand_c) - unsigned(result_s & "00"));
else
end if;
end if;
end process;
phi_frac_o <= phi_frac_s(13 downto 0);
end rtl;
And the testbench code is as follows:
entity tb_tdc_readout is
end tb_tdc_readout;
architecture beh of tb_tdc_readout is
component tdc_readout
end component;
--signal definition:
signal enable_i : std_logic := '0';
signal tdc_i : std_logic_vector(63 downto 0) := (others => '0');
signal scale_i : std_logic_vector(7 downto 0) := (others => '0');
signal doub_rise_fall_s : std_logic_vector(7 downto 0) := (others => '0');
signal shif_scale_s : std_logic_vector(11 downto 0) := (others => '0');
signal mult_s : std_logic_vector(13 downto 0) := (others => '0');
signal ph_frac_s : std_logic_vector(13 downto 0) := (others => '0');
signal rise_s : std_logic_vector(5 downto 0) := (others => '0');
signal phi_frac_o : std_logic_vector(13 downto 0) := (others => '0');
begin
--UUT Instance:
uut: tdc_readout
tdc_i => tdc_i,
scale_i => scale_i,
rise_fall_o => rise_fall_o,
phi_frac_o => phi_frac_o
.....................................................................code continues
..................................................................................................code continues
p_check_spi_phfrac: process(reset_n_i, clk_128meg_i)
begin
if (reset_n_i = '0') then
doub_rise_fall_s <= (others => '0');
shif_scale_s <= (others => '0');
mult_s <= (others => '0');
ph_frac_s <= (others => '0');
rise_s <= (others => '0');
elsif (clk_128meg_i'event and clk_128meg_i = '1') then
if (enable_i = '1') then
doub_rise_fall_s <= (rise_fall_o & '0');
shif_scale_s <= ("0000" & scale_i) ;
mult_s <= std_logic_vector(unsigned(rise_s) * unsigned(shif_scale_s));
ph_frac_s <= std_logic_vector("00000000000001" - unsigned(mult_s));
else
end if;
end if;
end process;
end beh;
Don't worry about the logic. Its not important right now. What's important is I need to use the values of rise_o from tb_tdc_decode/tdc_decode and use it in tb_tdc_readout because if you have a look at the tb_tdc_readout, you can see a statement " mult_s <= std_logic_vector(unsigned(rise_s) * unsigned(shif_scale_s));". This need to be executed. So, in order to execute this, I need the values of rise_o from either the testbench or the source file of tdc_decode. This is what I can provide you as extra information. I hope so you will figure it out from this. Thanks in advance
