14 years agoHelp me with this problem
I want to create a project with Quartus II and its function is to enable three different leds deppending on a code. When you are entering the code, the first led will be ON. Depending on the code entered, the second or the third will be ON. My problem is, when the code is correct I want the second led to be ON 3 seconds, and if it's incorrect, the third led will be ON during 2 seconds. It would be great if you help me. Thank you! Notes: leds are declared as a Logic Vector and the numbers of the code are declared as interrup from 0 to 7. Code:
library IEEE;use IEEE.STD_LOGIC_1164.ALL;
ENTITY programa IS
PORT
interrup : in Std_Logic_Vector (7 downto 0);
clk, rst: in Std_Logic;
led : out Std_Logic_Vector (2 downto 0)
END programa;
ARCHITECTURE arch_programa OF programa IS
type state is (zero, one, two, three, four, five, six);
signal pr_state, nx_state : state;
signal A : Std_Logic_Vector (3 downto 0);
BEGIN
process(interrup, pr_state)
begin
case pr_state is
when zero =>
led <= "100";
A(0) <= interrup(7);
nx_state <= one;
when one =>
led <= "100";
A(1) <= interrup(6);
nx_state <= two;
when two =>
led <= "100";
A(2) <= interrup(5);
nx_state <= three;
when three =>
led <= "100";
A(3) <= interrup(3);
nx_state <= four;
when four =>
led <= "100";
if(A = "1111") then nx_state <= five;
else nx_state <= six;
end if;
when five =>
led <= "010";
nx_state <=zero;
when six =>
led <= "001";
nx_state <=zero;
end case;
end process;
process(rst,clk)
begin
if(rst='1') then
pr_state <= zero;
elsif (clk'event and clk = '1') then
pr_state <= nx_state;
end if;
end process;
end arch_programa;
