14 years ago
Help - Quartus never completes Analysis/Synthesis
Hi - I'm dead-in-the-water after 3 hours of debugging. I have a small (21K ALUT) design on a Stratix-IV FPGA. It's a DSP design, and in
several places I re-use a small parameterized module called "shft_rnd_sat". (you can guess what it does 8-}).
I recently put it in 1 additional place in the design (to replace a shift-only operation), and now the compile stalls 46% of the way in. It runs in excess of 30 minutes stuck at this point (it normally takes 2 minutes to get past this point).
I've isolated it down to a single line of code - the round. I have this unconditional line
data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '1');
If I change it to
data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '0');
or even
data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) or ((data_in_len-rshift-1 downto 1 => '0') & '1');
everything works fine.
I made a copy of the module that is instantiated only in the 1 new place, and changing only that copy as noted above is sufficient to turn
on/off the problem.
ALSO - I should mention that my design has a top-level that is little more than a generate statement with 8 instantiations of a 2.6K ALUT 'main' module which (down the hierarchy a bit) contains the troubling module. If I work with the 'main' module alone it compiles fine, however, when I try to build with 2 or more main modules instantiated (either using a generate or explicit instantiation), then it hangs. It's very predictable and repeatable.
Without the problem it gets past this point in 2 minutes. With the problem it runs at least 30 minutes. (It might converge overnight but that's not a fix as it will make it hard to move forward).
I don't know how to go about debugging it. I've tried recoding the module a few different ways to no avail.
Any ideas? Anyone?
Thanks!
/j
(running 64b Quartus 11.2 SP2 on CentOS)
    For anyone interested - here's the entire module. It's instantiated only ONE place in the 'main' module. There are 2 lines of code highlighted. If either one is changed from what it is to what I want, the compile hangs 2 minutes in, on "Duplicate registers merged into single register". When it doesn't hang, it generates the "duplicate registers" message 2 more times, and then begins inferring, elaborating, and instantiating megafunctions.
    help? 8-}
    /j
    library ieee;
    use IEEE.std_logic_signed.all;
    use ieee.std_logic_1164.all;
    -- saturates top sat_wid bits and then delivers next data_out_len significant bits
    entity shft_rnd_sat0 is
    generic (
    data_in_len : integer;
    data_out_len : integer;
    rshift : integer
    port (
    data_in : in std_logic_vector (data_in_len -1 downto 0);
    data_out : out std_logic_vector (data_out_len -1 downto 0)
    end shft_rnd_sat0;
    architecture rtl of shft_rnd_sat0 is
    constant din_shift_len : integer := data_in_len - rshift;
    -- constant sat_wid : integer := din_shift_len - data_out_len; -- GOOD
    constant sat_wid : integer := din_shift_len - data_out_len-1; -- WRONG, but permits compile
    signal data_in_shift_rnd : std_logic_vector (din_shift_len-1 downto 0);
    signal data_in_shift : std_logic_vector (din_shift_len-1 downto 0);
    signal sat_val : std_logic_vector (sat_wid downto 0);
    begin
    -- round operation
    data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '0'); -- WRONG, but permits compile
    -- data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '1'); -- GOOD
    process (all)
    begin
    -- if the rounding bit is 0, or if the value is
    -- max and can't be rounded, just shift into smaller container
    if ((data_in(rshift-1) = '0') or
    (data_in (data_in_len -1 downto rshift) = ('0' & (data_in_len-rshift-2 downto 0 => '1')))) then
    data_in_shift <= data_in (data_in_len -1 downto rshift);
    else
    -- otherwise shift and round into smaller container
    data_in_shift <= data_in_shift_rnd(din_shift_len-1 downto 0);
    end if;
    -- saturate smaller container downto output width
    sat_val <= data_in_shift (din_shift_len-1 downto din_shift_len - sat_wid-1);
    if (((sat_val = (sat_val'length-1 downto 0 => '0')) or
    (sat_val = (sat_val'length-1 downto 0 => '1'))) or (sat_wid = 0)) then
    data_out <= data_in_shift (data_out_len - 1 downto 0);
    elsif (sat_val(sat_val'length-1) = '1') then
    data_out <= ('1' & (data_out_len-2 downto 1 => '0') & '1'); -- symetric
    else
    data_out <= ('0' & (data_out_len-2 downto 0 => '1'));
    end if;
    end process;
    end;
