14 years agoFor anyone interested - here's the entire module. It's instantiated only ONE place in the 'main' module. There are 2 lines of code highlighted. If either one is changed from what it is to what I want, the compile hangs 2 minutes in, on "Duplicate registers merged into single register". When it doesn't hang, it generates the "duplicate registers" message 2 more times, and then begins inferring, elaborating, and instantiating megafunctions.
help? 8-} /j library ieee; use IEEE.std_logic_signed.all; use ieee.std_logic_1164.all; -- saturates top sat_wid bits and then delivers next data_out_len significant bits entity shft_rnd_sat0 is generic ( data_in_len : integer; data_out_len : integer; rshift : integer ); port ( data_in : in std_logic_vector (data_in_len -1 downto 0); data_out : out std_logic_vector (data_out_len -1 downto 0) ); end shft_rnd_sat0; architecture rtl of shft_rnd_sat0 is constant din_shift_len : integer := data_in_len - rshift; -- constant sat_wid : integer := din_shift_len - data_out_len; -- GOOD constant sat_wid : integer := din_shift_len - data_out_len-1; -- WRONG, but permits compile signal data_in_shift_rnd : std_logic_vector (din_shift_len-1 downto 0); signal data_in_shift : std_logic_vector (din_shift_len-1 downto 0); signal sat_val : std_logic_vector (sat_wid downto 0); begin -- round operation data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '0'); -- WRONG, but permits compile -- data_in_shift_rnd <= (data_in (data_in_len -1 downto rshift)) + ((data_in_len-rshift-1 downto 1 => '0') & '1'); -- GOOD process (all) begin -- if the rounding bit is 0, or if the value is -- max and can't be rounded, just shift into smaller container if ((data_in(rshift-1) = '0') or (data_in (data_in_len -1 downto rshift) = ('0' & (data_in_len-rshift-2 downto 0 => '1')))) then data_in_shift <= data_in (data_in_len -1 downto rshift); else -- otherwise shift and round into smaller container data_in_shift <= data_in_shift_rnd(din_shift_len-1 downto 0); end if; -- saturate smaller container downto output width sat_val <= data_in_shift (din_shift_len-1 downto din_shift_len - sat_wid-1); if (((sat_val = (sat_val'length-1 downto 0 => '0')) or (sat_val = (sat_val'length-1 downto 0 => '1'))) or (sat_wid = 0)) then data_out <= data_in_shift (data_out_len - 1 downto 0); elsif (sat_val(sat_val'length-1) = '1') then data_out <= ('1' & (data_out_len-2 downto 1 => '0') & '1'); -- symetric else data_out <= ('0' & (data_out_len-2 downto 0 => '1')); end if; end process; end;
