9 years ago
HelloWorld - compiler error, not able to generate hardware
Recently I bought the DE1-SoC Board for trying OpenCL with it.
- I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf"
- I have a valid licence.
- I have downloaded the BSP for the Board
After trying to compile a .cl -File (the vector_add example from the intel site) with the command:
aoc device/vector_add.cl -o bin/vector_add.aocx --report --board de1soc_sharedonly
I get the error: Compiler Error, not able to generate hardware.
The .log file gave me following error-text:
info (21057): implemented 12069 device resources after synthesis - the final resource count might be different
info (21058): implemented 13 input pins
info (21059): implemented 45 output pins
info (21060): implemented 57 bidirectional pins
info (21061): implemented 10410 logic cells
info (21064): implemented 1528 ram segments
info (21065): implemented 1 plls
info (21071): implemented 1 partitions
info: quartus prime analysis & synthesis was successful. 0 errors, 65 warnings
info: peak virtual memory: 1136 megabytes
info: processing ended: mon may 15 07:23:33 2017
info: elapsed time: 00:00:32
info: total cpu time (on all processors): 00:00:31
error (281039): finished parallel synthesis of 1 partition(s). 1 partitions did not finish parallel synthesis because there were errors
error (281040): partition "system_acl_iface_hps_hps_io_border:border" did not complete synthesis due to errors
info (144001): generated suppressed messages file /home/developer/workspace/opencl_intel_tutorial/opencl_example_vector_soc/vector_add/bin/vector_add/top.map.smsg
error: quartus prime analysis & synthesis was unsuccessful. 2 errors, 581 warnings
error: peak virtual memory: 1575 megabytes
error: processing ended: mon may 15 07:26:48 2017
error: elapsed time: 00:04:42
error: total cpu time (on all processors): 00:04:56
error (293001): quartus prime full compilation was unsuccessful. 4 errors, 581 warnings
error: flow compile (for project /home/developer/workspace/opencl_intel_tutorial/opencl_example_vector_soc/vector_add/bin/vector_add/top) was not successful
error: error: error(s) found while running an executable. see report file(s) for error message(s). message log indicates which executable was run last.
error (23031): evaluation of tcl script /home/developer/intelfpga_lite/16.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
error: quartus prime shell was unsuccessful. 11 errors, 581 warnings
error: peak virtual memory: 806 megabytes
error: processing ended: mon may 15 07:26:49 2017
error: elapsed time: 00:04:50
error: total cpu time (on all processors): 00:05:04
Google said that that "Error: Peak virtual memory: 806 megabytes" means that i´m using to much logic elements, but its just the vector-add example so I´m quite confused.
I hope someone can point out whats the problem.
    --- Quote Start ---
    I have the same problem. I have following versions of openCL and Quartus. Should I update the version of OpenCL? Is there any command to update the OpenCL version?
    --- Quote End ---
    From the download center > intel fpga sdk for opencl (http://dl.altera.com/opencl/16.1/?edition=standard&download_manager=direct) open the Updates tab, download intel fpga sdk for opencl v16.1 update 2, change the file permission for the setup (.run) file by running the command: chmod +x *.run, and run the file.
    I met the same issue.
    I tried the combination of version with upgrade but still didn't work:
    1. Quartus Prime Pro 16.1.0 and OpenCL SDK 16.1.0
    2. Quartus Prime Pro 16.1.2 and OpenCL SDK 16.1.0
    3. Quartus Prime Pro 16.1.2 and OpenCL SDK 16.1.2
    The error in the log file "quartus_sh_compile.log" is as below:
    Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile your design.
    Error (15744): In atom 'board_inst|pcie|pcie|altpcie_a10_hip_pipen1b|g_xc vr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g 3x8|phy_g3x8|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_in st|inst_twentynm_pma|gen_twentynm_hssi_pma_rx_sd.i nst_twentynm_hssi_pma_rx_sd'
    Error (15744): The settings must match one or more of these conditions:
    Error (15744): ( sup_mode == ENGINEERING_MODE ) OR ( prot_mode != PCIE_GEN3_RX ) OR ( sd_output_off == CLK_DIVRX_14 )
    Error (15744): But the following assignments violate the above conditions:
    Error (15744): sup_mode = USER_MODE
    Error (15744): prot_mode = PCIE_GEN3_RX
    Error (15744): sd_output_off = CLK_DIVRX_6
    Error (18590): The imported netlist contains settings that are not supported by the current version of the software. Import using the --timing_analysis_mode option, which ignores the errors and allows Timing Analysis to be run.
    Error: design::import_design -file base.qdb -overwrite failed!
    Error (23031): Evaluation of Tcl script /root/intelFPGA_pro/16.1/quartus/common/tcl/internal/qatm_import_design.tcl unsuccessful
    Error: Quartus Prime Compiler Database Interface was unsuccessful. 11 errors, 0 warnings
    Error: Peak virtual memory: 4554 megabytes
    Error: Processing ended: Mon Sep 18 02:40:32 2017
    Error: Elapsed time: 00:16:10
    Error: Total CPU time (on all processors): 00:16:09
    Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
    Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
    Error: Peak virtual memory: 1179 megabytes
    Error: Processing ended: Mon Sep 18 02:40:34 2017
    Error: Elapsed time: 00:16:13
    Error: Total CPU time (on all processors): 00:16:11
    Did you solve the problem? Could you let me know how do you solve it?
    Thank you!
    --- Quote Start ---
    --- Quote End ---
  • SBoda's avatar
    SBoda
    And here is quartus_sh_compile.log
    ERROR: packager tool failed to run. Check installation. Aborting compilation!
