9 years agoHelloWorld - compiler error, not able to generate hardware
Hello, Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have dow...
9 years agoI met the same issue.
I tried the combination of version with upgrade but still didn't work: 1. Quartus Prime Pro 16.1.0 and OpenCL SDK 16.1.0 2. Quartus Prime Pro 16.1.2 and OpenCL SDK 16.1.0 3. Quartus Prime Pro 16.1.2 and OpenCL SDK 16.1.2 The error in the log file "quartus_sh_compile.log" is as below: Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile your design. Error (15744): In atom 'board_inst|pcie|pcie|altpcie_a10_hip_pipen1b|g_xc vr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g3x8.phy_g 3x8|phy_g3x8|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_in st|inst_twentynm_pma|gen_twentynm_hssi_pma_rx_sd.i nst_twentynm_hssi_pma_rx_sd' Error (15744): The settings must match one or more of these conditions: Error (15744): ( sup_mode == ENGINEERING_MODE ) OR ( prot_mode != PCIE_GEN3_RX ) OR ( sd_output_off == CLK_DIVRX_14 ) Error (15744): But the following assignments violate the above conditions: Error (15744): sup_mode = USER_MODE Error (15744): prot_mode = PCIE_GEN3_RX Error (15744): sd_output_off = CLK_DIVRX_6 Error (18590): The imported netlist contains settings that are not supported by the current version of the software. Import using the --timing_analysis_mode option, which ignores the errors and allows Timing Analysis to be run. Error: design::import_design -file base.qdb -overwrite failed! Error (23031): Evaluation of Tcl script /root/intelFPGA_pro/16.1/quartus/common/tcl/internal/qatm_import_design.tcl unsuccessful Error: Quartus Prime Compiler Database Interface was unsuccessful. 11 errors, 0 warnings Error: Peak virtual memory: 4554 megabytes Error: Processing ended: Mon Sep 18 02:40:32 2017 Error: Elapsed time: 00:16:10 Error: Total CPU time (on all processors): 00:16:09 Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 1179 megabytes Error: Processing ended: Mon Sep 18 02:40:34 2017 Error: Elapsed time: 00:16:13 Error: Total CPU time (on all processors): 00:16:11 Did you solve the problem? Could you let me know how do you solve it? Thank you! --- Quote Start --- From the download center > intel fpga sdk for opencl (http://dl.altera.com/opencl/16.1/?edition=standard&download_manager=direct) open the Updates tab, download intel fpga sdk for opencl v16.1 update 2, change the file permission for the setup (.run) file by running the command: chmod +x *.run, and run the file. --- Quote End ---
