9 years agoHelloWorld - compiler error, not able to generate hardware
Hello, Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have dow...
9 years ago --- Quote Start --- I have the same problem. I have following versions of openCL and Quartus. Should I update the version of OpenCL? Is there any command to update the OpenCL version? (...) --- Quote End --- From the download center > intel fpga sdk for opencl (http://dl.altera.com/opencl/16.1/?edition=standard&download_manager=direct) open the Updates tab, download intel fpga sdk for opencl v16.1 update 2, change the file permission for the setup (.run) file by running the command: chmod +x *.run, and run the file.
