ACoga
7 years agoHello, In my design I keep getting hold time violation warnings. "From Node" and "To Node" in the TimeQuest indicate the same signal.
Most of the signals relate to NIOS. The design based on a single 100MHz clock. There is an additional clock 12.5MHz generated in pll in QSYS and connected only to epcs flash controller. I've seen sim...
ACoga
7 years agoHi @KhaiY_Intel ,
I haven't solved it yet. Not really clear how to overconstrain the hold warnings of the same clock To and From the same signal. The number of the warnings (I could see a few hundreds of them and don't know the exact number - could be much higher) makes me think that something basic is wrong.
I've tried to remove the .sdc file and leave only derive_pll_clocks, but this type of warnings still appears, so it is not the .sdc file issue.
I'm working with Quartus 16.1, someone advised me to try a newer version. I can try it on the next week.
If you have any new ideas, I'll appreciate it.
Thank you.
