ACoga
7 years agoHello, In my design I keep getting hold time violation warnings. "From Node" and "To Node" in the TimeQuest indicate the same signal.
Most of the signals relate to NIOS. The design based on a single 100MHz clock. There is an additional clock 12.5MHz generated in pll in QSYS and connected only to epcs flash controller. I've seen sim...
Abe
7 years agoOne way to resolve Hold issues, is to phase shift your clock. If the design uses a PLL, then you can phase shift the clock by a few degrees and see if the hold violations are resolved. I had a similar kind of issue with Hold violations in my Qsys design. I then shifted the generated clocks by 90 and re-compiled and the hold violations were gone, did see a better slack margin as well as Fmax of the design also went up.
