[HDL 9-806] Syntax error near "library IEEE".
I just started learning VHDL. The syntax I already have an my code is correct according to research I have done, but I keep getting this error that won't let me synthesis my code. I have pasted my code for you to look at. I am trying to turn on LED 15 of a NEXYS 4 when a person flips the switch. As a side note if anyone knows any resource to help learn VHDL that would be much appreciated.
`timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 09/09/2016 01:21:54 PM // Design Name: // Module Name: LED15 // Project Name: // Target Devices: // Tool Versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module LED15( library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity my_entity is port( switch : in STD_LOGIC; light_LED : out STD_LOGIC ); end my_entity; architecture Behavioral of my_arch of my_entity is begin if (switch = 1) then port_light_LED <= '1'; end if; end Behavioral;3 Replies
The library declaration needs to be outside the module. Also, the 'timescale statement might not be legal. I'm not sure, but I never use them in files fed to Quartus. It should go in the test bench, not in synthesized code.
`timescale and module are Verilog keywords, but your code is VHDL. Also in VHDL (pre 2008) comments are marked with --, not //
Remove the `timescale, module lines and // comments - Altera_Forum
It looks like he might have done new->verilog file and filled it with VHDL.
