Hard Reset Required After Each Boundary Scan Operation
Could you share:
1. The exact device at @1 (family & part number)?
2. The BSDL snippets for INSTRUCTION_OPCODE (SAMPLE/EXTEST/BYPASS/IDCODE) and BOUNDARY_LENGTH.
3. Whether there are other devices in the chain (what does get_device_names / jtagconfig show)?
Please find the response as below:
1. It is a customized JTAG board.
2. 0x00000000 is the EXTEST code and the boundary length is 48bits
3. No, It is the only device connected (soo far) in the chain.
- AqidAyman_Altera8 months ago
Sorry, as I do not quite understand what you mean on the customized JTAG board. What FPGA device are you using in this case?
Dear Customer,
Since there has been no response for a few days now, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support - Alkesh_shah8 months ago
Hello There,
It is a board with the JTAG pinouts and the USB transceiver. I cannot share more details about the board.
Would be great if you can help me with the provided info.
What I want is to reset the TAP-State after each boundary operation. Want to understand if this can be done using Quartus GUI application or Quartus Command line application.
If not then what are the other options.
I tried closing the device and session and reopening it, also tried sending the bypass and flush DR as shared in one of the discussions (Hard reset with USB-Blaster and Quartus | Altera Community), but nothing helped.
wanted to know if there is any command through which I can control the driver and send reset to the device?
BR,
Alkesh- Farabi_Altera8 months ago
Which Altera Part Number you are using?
regards,
Farabi
