9 years agoGlitchs on a counter
Hi everybody
I m facing a problem with quartus II and modelsim-altera. Here is my VHDL code :library ieee ;use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
--use ieee.std_logic_unsigned.all;
use work.all;
entity AD7960_Ctrl is
port(
m_clk_i: in std_logic; --100MHz clock for timing
reset_n_i: in std_logic; --reset signal active low
clk_o: out std_logic --clock out
end AD7960_Ctrl;
architecture behavioral of AD7960_Ctrl is
constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10011" ;
signal adc_tcyc_cnt: std_logic_vector(4 downto 0);
begin
clk_o<= '1' when adc_tcyc_cnt = "00010" else '0' ;
process (m_clk_i,reset_n_i,adc_tcyc_cnt)
begin
if (reset_n_i = '0') then
adc_tcyc_cnt <= ADC_CYC_CNT;
elsif (m_clk_i='1' and m_clk_i'Event)then
if adc_tcyc_cnt /= "00000" then
adc_tcyc_cnt <= std_logic_vector(unsigned(adc_tcyc_cnt) - 1) ;
else
end if ;
end if ;
end process;
end behavioral; And here my test bench: -- testbench for counter_3bit
-- Load Altera libraries for this chip
LIBRARY IEEE;
LIBRARY MAXII;
USE IEEE.STD_LOGIC_1164.ALL;
USE MAXII.MAXII_COMPONENTS.ALL;
entity ad7960_ctrl_tb is
end ad7960_ctrl_tb;
architecture testbench1 of ad7960_ctrl_tb is
signal m_clk_i: std_logic := '0'; --100MHz clock for timing
signal reset_n_i: std_logic:= '0'; --reset signal active low
signal clk_o: std_logic:= '0'; --clock out
constant clk_period_100 : time := 10ns;
begin
-- dut = device under test (same name as top project from Quartus)
dut : entity work.ad7960_ctrl
-- Map the ports from the dut to this testbench
port map (
m_clk_i=> m_clk_i ,
reset_n_i=> reset_n_i ,
clk_o=> clk_o
-- Clock process definitions( clock with 50% duty cycle is generated here.
MAIN_CLK_process :process
begin
m_clk_i<= not m_clk_i; wait for clk_period_100/2;
end process;
stim_proc: process
begin
wait for 13ns;
reset_n_i <='1';
wait;
end process;
end ; Here is the output waveforms: http://www.alteraforum.com/forum/attachment.php?attachmentid=13105&stc=1 As you can see a have kind of glitchs on the output signal when my counter adc_tcyc_cnt goes from 0 to 19. Critical warning in quartus are just : Critical Warning: The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command. Critical Warning: From m_clk_i (Rise) to m_clk_i (Rise) (setup and hold) and warning are just : Warning: Feature LogicLock is not available with your current license Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details I if a change : constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10011" ; by (for exemple) constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10100" ; there is no problem. I would apreciate any help thanks.2 Replies
I assume this is a post place and route simulation? These glitches occur because the clk_o signal is combinatorial.
Not all bits of the counter change at exactly the same time. So on the clock cycle with the glitch you momentarily get the value to match to output a 1 as the counter transitions back to 0. To prevent these glitches you should register the clk_o output. On a side note, why do you have an output called clk? Generating clicks on logic is not good practice and actually this doesn't look like a clock at all, more like a clock enable ( which is what you should generate). - Altera_Forum
Here are a few tricks from an old timer: synchronous enabled design. It solves so many problems...
https://www.dropbox.com/s/8z2rgxvisni71y6/syncdesign2.pdf?dl=0 (image is worth a thousand words...) Cheers!
