Generate Simulation Setup Script Fails
When I click on Tools>Generate Simulation Setup Script for IP the messages window reports that the command runs and says "Process finished" but no scripts are created.
This last worked about a month ago. No changes to the computer except for MS updates. When I tried running this command this week, it failed to update the scripts. I created a new project with a Nios V and tried to generate the scripts, and it didn't create the Mentor/msim_setup.tcl or Mentor/run_msim_setup.tcl, or the common/modelsim_files.tcl scripts.
I updated to Quartus 26.1 (was 25.1.1) and still no good.
OS is Windows 11 Pro Version 10.0.26200
Ok, got it to work. Added C:\altera_pro\26.1\qsys\bin to the path, opened a Windows command prompt, cd to the project directory, then ran the ip-setup-simulation.exe command with the same parameters when run by the GUI and it works (I still have to click yes on the User Account Control dialog). I don't know why it stopped working with the GUI Tools>Generate Simulation Setup Script for IP... command, but this is the workaround I used.
