11 years agoGenerate a Test bench Output files .Vht
Hello
I use recently Quartus II 13.1 I would like generate a Test bench Output files .Vht from Waveform/vector File .VWf but I was unsuccessful .The file .vwf is a separate window from Quartus . Before, I use Quartus II 7.2 and for to do that I generate a Waveform/vector File .VWf and from menu I click on the File => Export ,then it’s generate and open a Test bench Output files .Vht . Could you tell me how I can generate a vht from vwf file fom quartus II 13.1? Thant you .
