11 years ago --- Quote Start --- Thank a lot Siraj Muhammad I have now another problem! When I do Generate modelsim Testbennh and script from Quartus 13.1, It generate verilog HDL file . Here’s how I do. I set the format output VHD from : settings=>EDA Tool Settings=>simulations=>EDA Netlist Writer Settings and after Apply. After I generate the waveform/vector File and as you told me, Under Simulation menu, select "Generate ModelSim Testbench and script". But, It generate verilog HDL file. When I return at the settings page I surprise to see that quartus change the format, it put Verilog HDL! Could you describe the different Steps for get the Format output Vht and not Vt. Thank you again --- Quote End --- Actually I don't have any idea about that, I have just moved to ModelSim because I found so many problems with the Waveform Simulator. Plus, there are many features that will benefit you. I recommend using ModelSim and learning how to write testbench.
