9 years agoFully Synthesizable Fix Point package
Great- I'v just learned how to use fully synthesizable floating point arithmetic calculation (using MegaFunction/IP cores). Now, how can I implement fully synthesizable Fix point calculation? I couldn't find any MegaFunction/ IP cores for that purpose… Thanks a lot, Idan5 Replies
Fixed point aritmetic is just integer arithmetic, offset by 2^n. So no special IP is needed.
H;
Thanks alot for your quick response! Where can I find an example for this kind of code? Thanks againe... Idan - Altera_Forum
in VHDL - its simple, especially if you use the fixed point package:
this can all be done with the numeric_std package, but you need to keep track of the offset yourself.use ieee.fixed_pkg.all; .... signal a : sfixed(7 downto -8); -- 1 sign bit, 7 integer bits, 8 fraction bits - ie. integer offset by 2^8 signal b : sfixed(15 downto -16); ... b <= a*a; - Altera_Forum
Does the "fixed_pkg" is fully synthesizable?
--- Quote Start --- Does the "fixed_pkg" is fully synthesizable? --- Quote End --- Yes. While full support only comes with Quartus Pro 16.0, you can use the '93 compatible version for compilation. Otherwise all of this can be done with numeric_std, which is compatible with all versions of quartus.
