9 years agoFully Synthesizable Fix Point package
Hi, Great- I'v just learned how to use fully synthesizable floating point arithmetic calculation (using MegaFunction/IP cores). Now, how can I implement fully synthesizable Fix point calculation? ...
9 years ago --- Quote Start --- Does the "fixed_pkg" is fully synthesizable? --- Quote End --- Yes. While full support only comes with Quartus Pro 16.0, you can use the '93 compatible version for compilation. Otherwise all of this can be done with numeric_std, which is compatible with all versions of quartus.
