8 years ago
Full compulation for large IO pins
Hi
I would like to perform full compilation for component (not the Top Level) that has large IO pins. Im looking at over thousands bits in output bits. But I need to know the total LEs and Fmax of the that particular component. Any ways to do so? Apparently there would not be any device that can provides such large pins. Thanks
    --- Quote Start ---
    If you have large busses where bits interact with a large number of other bits, then the routing (and timing) will suffer. FPGAs benefit from pipelining, so often a design with high latency get process much more data than a huge parrallel implementation with low latency.
    --- Quote End ---
    So in that case, would inserting more pipelines would help?
    Possibly, I have no idea how you've implemented the design (and I have no experience with encryption algorithms)
    If it's currently some large amount of interdependent logic, the pipelines could reduce the interdependence per clock cycle (and hence reduce routing requirement)
    --- Quote Start ---
    --- Quote End ---
    Alright! thanks for the advice. I shall explore further on this!
