13 years ago
Forcing signal for Analyze & Compile at partition boundary
Does anyone know if it is possible to 'force' a signal to 0 on a lower level design partition boundary for synthesis?
The normal way would be to just change the RTL code, possibly with an `ifdef, but this is in external IP that I've been asked not to touch!
More specifically, the partitioned section has an input 'gscanenable' which ends up xnor'd with a clock and used on a couple of registers.
But even though gscanenable is tied to 1'b0 at the top level above this partition the optimizer can't see that the signal is always 0 and adds the xnor resulting in hold time errors. (It is otherwise fine as the clock is otherwise undisturbed.)
It would be extremely useful to have a line in the *.qsf file that forces the node to 0.
    Add a level of hierarchy that just instantiates the IP, passes all signals through as normal, but puts '0' in that pin. (An assignment would be easier, but that's the recommended way)
    Hi Rysc,
    Thanks for the speedy reply! Yes, this is what I'm doing above the top level partition. (Similar to the solution of inserting a dummy PLL to get the clocking right shown in the Quartus manual.)
    Unfortunately as this is at a lower level of the design (the FPU) and I would have to insert this passthrough module as a sort of 'shim' between the instantiating and sub-partition IP. It would certainly work, but I'd still end up changing the code (if only the instantiation).
    As I think that code modification is inevitable I will probably do:
    `if FPGA
    `define CPU_SCANENABLE 1'b0
    `else
    `define CPU_SCANENABLE scanenable
    `endif
    in the header file and substitute scanenable in the RTL for `cpu_scanenable
    If there is a 'new feature' list for Quartus, this would be a useful addition as I know I've bumped into similar issues before (on a competing synthesis tool!)
    ++Simon
