Fitter : Error PARALLELTERMINATIONCONTROL connected but does not used on-chip termination
I am implementing DDR3 sdram controller interface using qsys in Quartus II (13.1). I am able to generate the synthesis for this DDR3 controller in qsys. When I integrate this controller into my top block, I am able to complete the Analysis & Synthesis but it fail at the Fitter(Place & Route).
The errors are
Error (174068): Output buffer atom "bt820_fpga_ddr_top:i_ddr_top|ddr3_16_01:u0|ddr3_16_01_emif_0:emif_0|ddr3_16_01_emif_0_p0:p0|ddr3_16_01_emif_0_p0_memphy:umemphy|ddr3_16_01_emif_0_p0_new_io_pads:uio_pads|ddr3_16_01_emif_0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen[0].obuf_1" has port "PARALLELTERMINATIONCONTROL[0]" connected, but does not use calibrated on-chip termination
Error (174068): Output buffer atom "bt820_fpga_ddr_top:i_ddr_top|ddr3_16_01:u0|ddr3_16_01_emif_0:emif_0|ddr3_16_01_emif_0_p0:p0|ddr3_16_01_emif_0_p0_memphy:umemphy|ddr3_16_01_emif_0_p0_new_io_pads:uio_pads|ddr3_16_01_emif_0_p0_altdqdqs:dq_ddio[1].ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen[0].obuf_1" has port "SERIESTERMINATIONCONTROL[0]" connected, but does not use calibrated on-chip termination
I have added assignment
DQ* output termination series 50 ohm with Calibration
DQ* input termination parallel 50 ohm with Calibration
I disable dynamic ODT and ODT in the DDR3 controller.
How do I resolve these type of errors?
Thank,
1 Reply
- Deshi_Intel
You should not add in your own pin assignment setting for UNIPHY IP.
Instead you should be running the *_p0_pin_assignments.tcl script after Quartus synthesis compilation. (Page 35)
- https://www.intel.com/content/dam/altera-www/global/ja_JP/pdfs/literature/hb/external-memory/emi_ddr3up_ug.pdf
- The tcl script will help you to setup the UNIPHY IP pin setting accordingly
dlim
