ssph
5 years agoFitter : Error PARALLELTERMINATIONCONTROL connected but does not used on-chip termination
I am implementing DDR3 sdram controller interface using qsys in Quartus II (13.1). I am able to generate the synthesis for this DDR3 controller in qsys. When I integrate this cont...
Deshi_Intel
5 years agoHi,
You should not add in your own pin assignment setting for UNIPHY IP.
Instead you should be running the *_p0_pin_assignments.tcl script after Quartus synthesis compilation. (Page 35)
- https://www.intel.com/content/dam/altera-www/global/ja_JP/pdfs/literature/hb/external-memory/emi_ddr3up_ug.pdf
- The tcl script will help you to setup the UNIPHY IP pin setting accordingly
dlim
