--- Quote Start --- yes you should get [0 6 1 -10] Are you inputting x correctly just after clock edge. can you post how you drive x? --- Quote End --- thnx for the quick reply sir, im unable to paste the snap shot of the timing diagram plzzz help me seeing this .... i hve put 0-100ns---low clock 100-200----high clock [ for both of this xin=0] 200-300 ----low clock[xin= -3] 300-400-----high clock[xin= 1] 400-500------low clock[xin= 0] 500-600-------high clock[xin= -2] plzz reply me fast sir....... - Altera_Forum
--- Quote Start --- thnx for the quick reply sir, im unable to paste the snap shot of the timing diagram plzzz help me seeing this .... i hve put 0-100ns---low clock 100-200----high clock [ for both of this xin=0] 200-300 ----low clock[xin= -3] 300-400-----high clock[xin= 1] 400-500------low clock[xin= 0] 500-600-------high clock[xin= -2] plzz reply me fast sir....... --- Quote End --- I just simulated your code and it works. I only replaced your DFF with inferred registers: Here is the code(equivalent to yours, so no need to change anything):
Edit: I noted you are inputting x on high clock then another value on low clock. You should input data at full clock period i.e. low high period.library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity fir_4tap is port( Clk : in std_logic; --clock signal --Xin : in signed(7 downto 0); --input signal Yout : out signed(15 downto 0) --filter output ); end fir_4tap; architecture Behavioral of fir_4tap is signal H0,H1,H2,H3 : signed(7 downto 0) := (others => '0'); signal MCM0,MCM1,MCM2,MCM3,add_out1,add_out2,add_out3 : signed(15 downto 0) := (others => '0'); signal Q1,Q2,Q3 : signed(15 downto 0) := (others => '0'); signal Xin : signed(7 downto 0) := "00000000"; signal count : unsigned(4 downto 0) := "00000"; begin --filter coefficient initializations. --H = . H0 <= to_signed(-2,8); H1 <= to_signed(-1,8); H2 <= to_signed(3,8); H3 <= to_signed(4,8); --Multiple constant multiplications. MCM3 <= H3*Xin; MCM2 <= H2*Xin; MCM1 <= H1*Xin; MCM0 <= H0*Xin; --adders add_out1 <= Q1 + MCM2; add_out2 <= Q2 + MCM1; add_out3 <= Q3 + MCM0; process begin wait until Clk = '1'; count <= count + 1; if count = 0 then Xin <= to_signed(0,8); elsif count = 1 then Xin <= to_signed(-3,8); elsif count = 2 then Xin <= to_signed(1,8); else Xin <= to_signed(0,8); end if; Q1 <= MCM3; Q2 <= add_out1; Q3 <= add_out2; end process; --an output produced at every positive edge of clock cycle. process(Clk) begin if(rising_edge(Clk)) then Yout <= add_out3; end if; end process; end Behavioral; - Altera_Forum
--- Quote Start --- I just simulated your code and it works. I only replaced your DFF with inferred registers: Here is the code(equivalent to yours, so no need to change anything):
Edit: I noted you are inputting x on high clock then another value on low clock. You should input data at full clock period i.e. low high period. --- Quote End --- thnk u sir... thnk u very much ..........ivl reply u as soon as i simulate the code..library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity fir_4tap is port( Clk : in std_logic; --clock signal --Xin : in signed(7 downto 0); --input signal Yout : out signed(15 downto 0) --filter output ); end fir_4tap; architecture Behavioral of fir_4tap is signal H0,H1,H2,H3 : signed(7 downto 0) := (others => '0'); signal MCM0,MCM1,MCM2,MCM3,add_out1,add_out2,add_out3 : signed(15 downto 0) := (others => '0'); signal Q1,Q2,Q3 : signed(15 downto 0) := (others => '0'); signal Xin : signed(7 downto 0) := "00000000"; signal count : unsigned(4 downto 0) := "00000"; begin --filter coefficient initializations. --H = . H0 <= to_signed(-2,8); H1 <= to_signed(-1,8); H2 <= to_signed(3,8); H3 <= to_signed(4,8); --Multiple constant multiplications. MCM3 <= H3*Xin; MCM2 <= H2*Xin; MCM1 <= H1*Xin; MCM0 <= H0*Xin; --adders add_out1 <= Q1 + MCM2; add_out2 <= Q2 + MCM1; add_out3 <= Q3 + MCM0; process begin wait until Clk = '1'; count <= count + 1; if count = 0 then Xin <= to_signed(0,8); elsif count = 1 then Xin <= to_signed(-3,8); elsif count = 2 then Xin <= to_signed(1,8); else Xin <= to_signed(0,8); end if; Q1 <= MCM3; Q2 <= add_out1; Q3 <= add_out2; end process; --an output produced at every positive edge of clock cycle. process(Clk) begin if(rising_edge(Clk)) then Yout <= add_out3; end if; end process; end Behavioral; - Altera_Forum
did u simulate the code that u have sent sir???
yes and I said that.
You can just drive your inputs as follows: clk low 0-99, high 100-199 @ 101 ---- xin=0 @ 301 ----xin= -3 @ 401 -----xin= 1 @ 601 ------xin= 0 @ 801 -------xin= -2 - Altera_Forum
--- Quote Start --- yes and I said that. You can just drive your inputs as follows: clk low 0-99, high 100-199 @ 101 ---- xin=0 @ 301 ----xin= -3 @ 401 -----xin= 1 @ 601 ------xin= 0 @ 801 -------xin= -2 --- Quote End --- hello sir, i simulated the code...in the timing diagram now there are clock and o/ps (as inputs are given in the code itself) i have put clock high and even tried for low-high clock pluse but the o/p is y=0 only zero. thanx for the cooperation sir plzz do reply - Altera_Forum
if possible plzz upload ur timing diagram snapshot sir
sir got it sir but y=[0 6 1] only three o/ps
sir got it ...thnx a lot sir .thnx u very much .tomm is my project submission .nw i can have a very big smile when submitting.....
