13 years ago --- Quote Start --- yes and I said that. You can just drive your inputs as follows: clk low 0-99, high 100-199 @ 101 ---- xin=0 @ 301 ----xin= -3 @ 401 -----xin= 1 @ 601 ------xin= 0 @ 801 -------xin= -2 --- Quote End --- hello sir, i simulated the code...in the timing diagram now there are clock and o/ps (as inputs are given in the code itself) i have put clock high and even tried for low-high clock pluse but the o/p is y=0 only zero. thanx for the cooperation sir plzz do reply
