13 years ago
fir filter code in vhdl [plzzzzzz reply as fast as possible plzzzz]
I have attached a file .
this is my code for 4tap fir filter.but there is a problem.the o/p i get is not getting verified with the formula of fir.y(n)=h(n)*x(n) plzzzzz help me.
plzz help!!!!!
coding is done using the transpose form of fir filter
    --- Quote Start ---
    yes you should get [0 6 1 -10]
    Are you inputting x correctly just after clock edge. can you post how you drive x?
    --- Quote End ---
    thnx for the quick reply sir,
    im unable to paste the snap shot of the timing diagram
    plzzz help me seeing this ....
    i hve put 0-100ns---low clock
    100-200----high clock [ for both of this xin=0]
    200-300 ----low clock[xin= -3]
    300-400-----high clock[xin= 1]
    400-500------low clock[xin= 0]
    500-600-------high clock[xin= -2]
    plzz reply me fast sir.......
    --- Quote Start ---
    --- Quote End ---
    I just simulated your code and it works.
    I only replaced your DFF with inferred registers: Here is the code(equivalent to yours, so no need to change anything):
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.NUMERIC_STD.ALL;
    entity fir_4tap is
    port(   Clk : in std_logic; --clock signal
            --Xin : in signed(7 downto 0); --input signal
            Yout : out signed(15 downto 0)  --filter output
    end fir_4tap;
    architecture Behavioral of fir_4tap is
    signal H0,H1,H2,H3 : signed(7 downto 0) := (others => '0');
    signal MCM0,MCM1,MCM2,MCM3,add_out1,add_out2,add_out3 : signed(15 downto 0) := (others => '0');
    signal Q1,Q2,Q3 : signed(15 downto 0) := (others => '0');
    signal Xin : signed(7 downto 0) := "00000000";
    signal count : unsigned(4 downto 0) := "00000";
    begin
    --filter coefficient initializations.
    --H = .
    H0 <= to_signed(-2,8);
    H1 <= to_signed(-1,8);
    H2 <= to_signed(3,8);
    H3 <= to_signed(4,8);
    --Multiple constant multiplications.
    MCM3 <= H3*Xin;
    MCM2 <= H2*Xin;
    MCM1 <= H1*Xin;
    MCM0 <= H0*Xin;
    --adders
    add_out1 <= Q1 + MCM2;
    add_out2 <= Q2 + MCM1;
    add_out3 <= Q3 + MCM0;
    process
    begin
    wait until Clk = '1';
    count <= count + 1;
    if count = 0 then
      Xin <= to_signed(0,8);
    elsif count = 1 then
      Xin <= to_signed(-3,8);
    elsif count = 2 then
      Xin <= to_signed(1,8);
    else
    end if;
    Q1 <= MCM3;
    Q2 <= add_out1;
    Q3 <= add_out2;
    end process;
    --an output produced at every positive edge of clock cycle.
    process(Clk)
    begin
        if(rising_edge(Clk)) then
            Yout <= add_out3;
        end if;
    end process;
    end Behavioral;
    Edit: I noted you are inputting x on high clock then another value on low clock. You should input data at full clock period i.e. low high period.
    --- Quote Start ---
    library IEEE;
    entity fir_4tap is
    end fir_4tap;
    begin
    --H = .
    MCM3 <= H3*Xin;
    MCM2 <= H2*Xin;
    MCM1 <= H1*Xin;
    MCM0 <= H0*Xin;
    --adders
    process
    begin
    count <= count + 1;
    if count = 0 then
    else
    end if;
    Q1 <= MCM3;
    Q2 <= add_out1;
    Q3 <= add_out2;
    end process;
    process(Clk)
    begin
            Yout <= add_out3;
        end if;
    end process;
    end Behavioral;
    --- Quote End ---
    thnk u sir... thnk u very much ..........ivl reply u as soon as i simulate the code..
    yes and I said that.
    You can just drive your inputs as follows:
    clk low 0-99, high 100-199
    @ 101 ---- xin=0
    @ 301 ----xin= -3
    @ 401 -----xin= 1
    @ 601 ------xin= 0
    @ 801 -------xin= -2
    --- Quote Start ---
    @ 101 ---- xin=0
    @ 301 ----xin= -3
    @ 401 -----xin= 1
    @ 601 ------xin= 0
    --- Quote End ---
    hello sir, i simulated the code...in the timing diagram now there are clock and o/ps (as inputs are given in the code itself) i have put clock high and even tried for low-high clock pluse but the o/p is y=0 only zero.
    thanx for the cooperation sir plzz do reply
    sir got it ...thnx a lot sir .thnx u very much .tomm is my project submission .nw i can have a very big smile when submitting.....
