Find where false_path was set.
I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be due to a false path or the setting of asynchronous clock groups. Are there any other possibilities?
Is there a way to identify where the false path or asynchronous clock groups were set? maybe , in which SDC file and line?
- RichardT_altera
Could you please share your design by archiving the project (Project > Archive Project) so I can investigate it further?
Also, kindly provide the timing path that isn't being captured in the Timing Analyzer.
Richard Tan
- OrF
I’ve attached the QAR file. I’m not sure what files are inside the QAR, but the timing constraints I would like to expand are as follows:
set_false_path -from [get_clocks {rx_*}] -to [get_clocks {pll_*}]
set_output_delay -add_delay -max -clock [get_clocks {tx_clk}] 47.000 [get_ports {DIE0_dib_pad_0_*_*[*]}]
set_output_delay -add_delay -min -clock [get_clocks {tx_clk}] 0.000 [get_ports {DIE0_dib_pad_0_*_*[*]}]In my project, these constraints are located in the file scf_manual_addition.scf.
I’m not sure what the QAR will generate, but my expectation is that the * will be expanded in any of the three cases.
Or - RichardT_altera
The timing analyzer does not expand the wildcards(*) list unfortunately, but you can right-click and View Matching, to examine the collections in the wildcards that you specified.
Alternatively, you can go to the Timing Analyzer GUI, View > Name Finder to check and experiment with collections using the wildcards.
Richard Tan
- RichardT_altera
Do you have further question in regards to this case?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
