Failure to generate companion license for Modelsim-Altera
I am trying to generate a companion license for my home computer by opening the window "Generate Companion/Temporary Check-out Licenses". However, every time the hostid in the generated license file points to my primary computer, not the companion ID specified on the web page.
Here is the diagnostic I get from the license management tools:
================================== begin
Diagnostics
FlexNet diagnostics on Fri 3/27/2020 13:09
License file: C:\altera\15.0\license.dat
"alteramtivsim" v2021.03, vendor: mgcld uncounted nodelocked license, locked to ethernet address "8851fb6b4d2e" starts: 27-mar-2020, expires: 27-mar-2021
This license cannot be checked out because: Invalid host.
The hostid of this system does not match the hostid specified in the license file.
Feature: alteramtivsim
Hostid: 8851fb6b4d2e - this is the hostid of the primary computer
License path: C:\altera\15.0\license.dat;
FlexNet Licensing error:-9,57
================================== end
My companion hostid is nowhere to be found in the license file.
- AR_A_Intel
could you provide the latest license.dat file that you generate and also the NICID for the companion license.
- GNote
You already requested this information and I provided it in one of the messages above. Here I do copy & paste from the previous message:
- Companion NIC ID is 000C29821BD7
- Machine OS is Windows 7
- Here is the license file
======================================================== license file begins
# Intel Corporation Software and/or Intellectual Property License File
# Issued 27 March 2020
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-GN_WIN7_2015
# Primary Machine ID-NIC ID 8851FB6B4D2E
# Companion ID-NIC ID 84A93E60A2E0
# Companion ID 2-NIC ID 000C29821BD7
# Product License Summary:
# ModelSim Intel FPGA Edition Software, 1 Seat(s)
# - Maintenance Expiration of 2016.11
# - License Expires 27-Mar-2021
# FEATURE START
# The following is a license file for the ModelSim
# Number of seat licenses is 1
# License Expires 27-Mar-2021
INCREMENT alteramtivsim mgcld 2021.03 27-mar-2021 uncounted \
FF40057B5E9DD762320F \
VENDOR_STRING=6FB5F269 HOSTID=8851fb6b4d2e ISSUER=Intel SN=71038913 \
SIGN2="1813 C9D6 4DEF B1A4 5D69 2009 66C6 0E36 79C8 428E 3006 7EBC \
611D 3969 0EF3 05D9 D129 60C8 75F6 3464 A6F9 046D 5150 2FF5 1423 57A4 \
1E5E C753 D558 6C18"
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 03/27/2020
======================================================== license file ends
- AR_A_Intel
Hi, we PM you a private message
- DamBam
Hello @GNote and @AR_A_Intel ,
Could You please share the solution to this issue?
I have the same issue as only primary ID station can run Intel-Modelsim normally ;(
Thanks in advance
