Mads_From_Denmark's avatar
Mads_From_Denmark
2 months ago
Failed to run ip-setup-simulation:
Hello Altera Community.
I'm trying to simulate an example generated by the FPGA AI Suite. However I get a list of errors which is attached below in a txt file.
In Settings -> IP Simulation
CHECKED: Generate IP Sim model
FLOW: QRUN
SIMULATORS: QuestaSIM
It seems like the example is already setup for simulation expect its missing a testbench.
I am running Quartus in admin mode. I have installed EDA Lib. I have installed Questa.
What should I do to get it working?
  • The error indicates that the .spd files are not found. Have you generated the simulation files for your Qsys system?
    Richard Tan
    • Mads_From_Denmark's avatar
      Mads_From_Denmark
      It seems that it is not possible to generate a simulation for the systems in the example.
      Error: altera_ai_ip_2: altera_ai_ip does not support generation for VHDL Simulation. Generation is available for: Quartus Synthesis.
      Error: SPD file was not generated: C:\Users\mads\Desktop\agx5_soc_s2m_lt\hw\qsys\ip\dla\dla_altera_ai_ip_2\dla_altera_ai_ip_2.spd
