9 years agoExpression has 32 elements ; expected 16
Hi evryone !
Plz help I have some problems in my modul, i get errors in : Line 71: Expression has 32 elements ; expected 16 Line 47: Expression has 9 elements ; expected 16 The tow lines : line 47 : wr <= curr_depth_bufbuf; line 71 : shift_p <= 2*shift_p; The declarations of generic and ports are the following with the signals also : generic ( MAX_DEPTH : integer := 9; -- max tree depth HASH_LENGTH : integer := 2; -- hash length in words BLOCK_LENGTH : integer := 32; -- block length in words MEM_WIDTH : integer := 16); -- word width port ( clk : in std_logic; rstb : in std_logic; -- active low async reset start : in std_logic; -- start bit path_depth : in std_logic_vector(MAX_DEPTH-1 downto 0); -- one hot w_beta : in std_logic_vector(MAX_DEPTH-1 downto 0); -- selected node; ptr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- pointer value wr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- enable ptr writre status : out std_logic); -- finish bit signal curr_depth, curr_depth_buf, curr_depth_bufbuf : std_logic_vector(MAX_DEPTH-1 downto 0); signal leftright, leftright_buf, status_tmp, leaf : std_logic; -- 1 is goto branch 1 signal shift_w, shift_p, w_addr, p_addr : unsigned(MEM_WIDTH-1 downto 0); constant root_addr : integer := 2**MAX_DEPTH; Thank you10 Replies
curr_depth_bufbuf has width 9, but wr has width 16.
Simalarly for the other line you need to set the generics correctly or change the code so the widths match. - Altera_Forum
Thank you for your reply
The other line is the same signal is a register that I multiply by 2 shift_p <= 2*shift_p; error --> Expression has 32 elements ; expected 16 His type is unsigned like you see ! - Altera_Forum
Presumed you are using numeric_std library, the both errors can be fixed by writing:
In the first case, you have the problem, that the bit width of unsigned multiply increases the bit width. Resize cuts the additional bits on the left, necessary to assign the result to signal with fixed bit width. Similarly curr_depth_bufbuf must be zero filled on the left, resize can also do it. There are many other ways to achieve the same.shift_p <= shift_left(shift_p,1); -- or shift_p <= resize(2*shift_left,MEM_WIDTH); wr <= resize(curr_depth_bufbuf, MEM_WIDTH); - Altera_Forum
Yes, i am using numeric_std library
Knowing that resize return UNSIGNED in the case of an unsigned argument After changing the code, I get this mistakes 47: Expecting type std_logic_vector for <resize>. 71: Formal <arg> has no actual or default value. - Altera_Forum
http://www.alteraforum.com/forum/attachment.php?attachmentid=13168&stc=1
You will find enclosed my code file I have fixed these errors by passing from vector to unsigned but :( Here my process : Plz can you clarify me more about this process -- purpose: Compute shifts shift_proc: process (clk, start) is begin -- process if start = '0' then shift_p <= (others => '1'); shift_w <= (others => '0'); p_addr <= to_unsigned(root_addr, 16) + to_unsigned(hash_length, 16); elsif clk'event and clk = '1' then -- rising clock edge if leftright = leftright_buf then shift_p <= resize(2*shift_left, MEM_WIDTH); shift_w <= shift_w + shift_p; else shift_w <= resize(2*shift_left, MEM_WIDTH); shift_p <= shift_w + shift_p; end if; p_addr <= p_addr - shift_p*hash_length; if leaf='0' then w_addr <= p_addr - shift_w*hash_length; else w_addr <= p_addr - (unsigned(w_beta)/2)*hash_length - (shift_w-(unsigned(w_beta)/2))*block_length; end if; end if; end process; p_addr <= p_addr - shift_p*hash_length; w_addr <= p_addr - shift_w*hash_length; w_addr <= p_addr - (unsigned(w_beta)/2)*hash_length - (shift_w-(unsigned(w_beta)/2))*block_length; - Altera_Forum
--- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; --use ieee.std_logic_unsigned.all; entity witness is generic ( MAX_DEPTH : integer := 9; -- max tree depth HASH_LENGTH : integer := 2; -- hash length in words BLOCK_LENGTH : integer := 32; -- block length in words MEM_WIDTH : integer := 16); -- word width port ( clk : in std_logic; rstb : in std_logic; -- active low async reset start : in std_logic; -- start bit path_depth : in std_logic_vector(MAX_DEPTH-1 downto 0); -- one hot w_beta : in std_logic_vector(MAX_DEPTH-1 downto 0); -- selected node; ptr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- pointer value wr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- enable ptr writre status : out std_logic); -- finish bit end entity witness; architecture arch of witness is signal curr_depth, curr_depth_buf, curr_depth_bufbuf : unsigned(MAX_DEPTH-1 downto 0); signal leftright, leftright_buf, status_tmp, leaf : std_logic; -- 1 is goto branch 1 signal shift_w, shift_p, w_addr, p_addr : unsigned(MEM_WIDTH-1 downto 0); constant root_addr : integer := 2**(MAX_DEPTH)-1; begin -- architecture arch -- purpose: Buffer some signals buf: process (clk, rstb) is begin -- process buf if clk'event and clk = '1' then -- rising clock edge curr_depth_bufbuf <= curr_depth_buf; curr_depth_buf <= curr_depth; leftright_buf <= leftright; end if; end process buf; leftright <= '0' when (unsigned(w_beta) and curr_depth) = (9 downto 0 => '0') else '1'; --bitwise leaf <= path_depth(MAX_DEPTH-1) and curr_depth_buf(0); ptr <= std_logic_vector(w_addr); wr <= std_logic_vector(resize(curr_depth_bufbuf, MEM_WIDTH)); -- purpose: shift current depth -- type : sequential shift_depth: process (clk, rstb) is begin -- process shift_depth if clk'event and clk = '1' then -- rising clock edge if start = '0' then curr_depth <= unsigned(path_depth); else curr_depth <= '0' & curr_depth(MAX_DEPTH-1 downto 1); --which level we are in the tree end if; end if; end process shift_depth; -- purpose: Compute shifts shift_proc: process (clk, start) is begin -- process if start = '0' then shift_p <= (others => '1'); shift_w <= (others => '0'); p_addr <= to_unsigned(root_addr, 16) + to_unsigned(hash_length, 16); elsif clk'event and clk = '1' then -- rising clock edge if leftright = leftright_buf then shift_p <= resize(2*shift_left, MEM_WIDTH); shift_w <= shift_w + shift_p; else shift_w <= resize(2*shift_left, MEM_WIDTH); shift_p <= shift_w + shift_p; end if; p_addr <= p_addr - shift_p*hash_length; if leaf='0' then w_addr <= p_addr - shift_w*hash_length; else w_addr <= p_addr - (unsigned(w_beta)/2)*hash_length - (shift_w-(unsigned(w_beta)/2))*block_length; end if; end if; end process; -- purpose: Handle status bit status_proc: process (clk, rstb) is begin -- process status_proc if rstb = '0' then -- asynchronous reset (active low) status_tmp <= '0'; elsif clk'event and clk = '1' then -- rising clock edge status_tmp <= status_tmp or curr_depth_bufbuf(0); end if; end process status_proc; status <= status_tmp; end architecture arch; --- Quote End --- here is my code can plz clarify me more about the process "compute shift" - Altera_Forum
What exactly do you need clarifying?
For example, for this registres.
what does it mean when we do this In terms of movement of bit : shift_p <= 2*shift_left; or shift_w <= shift_w + shift_p; this also p_addr <= p_addr - shift_p*hash_length; - Altera_Forum
multiplying a number by 2^N shifts a number to the left by N bits.
The second line is just a normal subtract. - Altera_Forum
thank you, but i still not understand all the process, I will make a test bench and return to you :)
