9 years agoExpression has 32 elements ; expected 16
Hi evryone ! Plz help I have some problems in my modul, i get errors in : Line 71: Expression has 32 elements ; expected 16 ...
9 years ago --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; --use ieee.std_logic_unsigned.all; entity witness is generic ( MAX_DEPTH : integer := 9; -- max tree depth HASH_LENGTH : integer := 2; -- hash length in words BLOCK_LENGTH : integer := 32; -- block length in words MEM_WIDTH : integer := 16); -- word width port ( clk : in std_logic; rstb : in std_logic; -- active low async reset start : in std_logic; -- start bit path_depth : in std_logic_vector(MAX_DEPTH-1 downto 0); -- one hot w_beta : in std_logic_vector(MAX_DEPTH-1 downto 0); -- selected node; ptr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- pointer value wr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- enable ptr writre status : out std_logic); -- finish bit end entity witness; architecture arch of witness is signal curr_depth, curr_depth_buf, curr_depth_bufbuf : unsigned(MAX_DEPTH-1 downto 0); signal leftright, leftright_buf, status_tmp, leaf : std_logic; -- 1 is goto branch 1 signal shift_w, shift_p, w_addr, p_addr : unsigned(MEM_WIDTH-1 downto 0); constant root_addr : integer := 2**(MAX_DEPTH)-1; begin -- architecture arch -- purpose: Buffer some signals buf: process (clk, rstb) is begin -- process buf if clk'event and clk = '1' then -- rising clock edge curr_depth_bufbuf <= curr_depth_buf; curr_depth_buf <= curr_depth; leftright_buf <= leftright; end if; end process buf; leftright <= '0' when (unsigned(w_beta) and curr_depth) = (9 downto 0 => '0') else '1'; --bitwise leaf <= path_depth(MAX_DEPTH-1) and curr_depth_buf(0); ptr <= std_logic_vector(w_addr); wr <= std_logic_vector(resize(curr_depth_bufbuf, MEM_WIDTH)); -- purpose: shift current depth -- type : sequential shift_depth: process (clk, rstb) is begin -- process shift_depth if clk'event and clk = '1' then -- rising clock edge if start = '0' then curr_depth <= unsigned(path_depth); else curr_depth <= '0' & curr_depth(MAX_DEPTH-1 downto 1); --which level we are in the tree end if; end if; end process shift_depth; -- purpose: Compute shifts shift_proc: process (clk, start) is begin -- process if start = '0' then shift_p <= (others => '1'); shift_w <= (others => '0'); p_addr <= to_unsigned(root_addr, 16) + to_unsigned(hash_length, 16); elsif clk'event and clk = '1' then -- rising clock edge if leftright = leftright_buf then shift_p <= resize(2*shift_left, MEM_WIDTH); shift_w <= shift_w + shift_p; else shift_w <= resize(2*shift_left, MEM_WIDTH); shift_p <= shift_w + shift_p; end if; p_addr <= p_addr - shift_p*hash_length; if leaf='0' then w_addr <= p_addr - shift_w*hash_length; else w_addr <= p_addr - (unsigned(w_beta)/2)*hash_length - (shift_w-(unsigned(w_beta)/2))*block_length; end if; end if; end process; -- purpose: Handle status bit status_proc: process (clk, rstb) is begin -- process status_proc if rstb = '0' then -- asynchronous reset (active low) status_tmp <= '0'; elsif clk'event and clk = '1' then -- rising clock edge status_tmp <= status_tmp or curr_depth_bufbuf(0); end if; end process status_proc; status <= status_tmp; end architecture arch; --- Quote End --- here is my code can plz clarify me more about the process "compute shift"
