16 years ago
expression has 2 elements, but must have 4 elements
Hey guys,
This is trashing my brain, please help.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY shifter  IS
PORT (
        A: IN UNSIGNED (1 downto 0);
        B: IN UNSIGNED (1 downto 0);
        OUTPUT : OUT UNSIGNED (3 downto 0)
END shifter;
ARCHITECTURE identifier OF shifter IS
BEGIN
    process(A,B)
    variable C : INTEGER range 0 to 15;
    BEGIN
            C := TO_INTEGER(B);
            OUTPUT <= A sll C;
        END PROCESS;
END identifier;
Logs:
Error (10344): VHDL expression error at shift.vhd(23): expression has 2  elements, but must have 4 elements
which means this line
OUTPUT <= A sll C;
    I think you are making some confusion with types.
    Infact:
    A and B are defined as an array of 2 unsigned elements
    OUTPUT is defined as an array of 4 unsigned elements
    OUTPUT <= A sll C shifts left A by C (=B) bits
    I'm not a vhdl expert but I think than sll must always operate on a bit vector (error1: here you have an unsigned int vector) ; then you assign the result to a different size array (error2: A size 2, OUTPUT size 4)
    Probably you are confusing array dimensions with ranges.
    Thanks that worked.
    I only had to make this change
    A: IN UNSIGNED (3 downto 0);
    --- Quote Start ---
    Infact:
    --- Quote End ---
    sll is defined for bit_vector, unsigned and signed.
    Another way to may it work would have been:
    output <= ("00" & A) sll C;
