16 years ago --- Quote Start --- I think you are making some confusion with types. Infact: A and B are defined as an array of 2 unsigned elements OUTPUT is defined as an array of 4 unsigned elements OUTPUT <= A sll C shifts left A by C (=B) bits I'm not a vhdl expert but I think than sll must always operate on a bit vector (error1: here you have an unsigned int vector) ; then you assign the result to a different size array (error2: A size 2, OUTPUT size 4) Probably you are confusing array dimensions with ranges. --- Quote End --- sll is defined for bit_vector, unsigned and signed. Another way to may it work would have been: output <= ("00" & A) sll C;
