16 years ago
Errors: Quartus II 9.0 with my full license.
I have my IT guy just installed my full license and try to recompile my project with Quartus II 9.0.
But I still get this file generate after DemoA_time_limited.sof. So my questions: Does the IT guy install licence correctly? Why I still get time_limited.sof file?
Sean
    You can go in the Tools menu and select License Setup to check the status of your license.
    Do you have the licenses for all the IPs that you use in your design? If you have licensed IPs in SOPC builder, you may have to regenerate the system after having installed the license.
    I have a vendor FAE takes a look at it. The errors.
    Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2
    Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCE1
    Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCEC
    --- Quote Start ---
    --- Quote End ---
    it looks like that you use an IP block which is not covert with the subscription licence.
    Have a look to your design and find out which IP's you are using and compared it with
    the IP's which are included,
    Kind regards
    GPK
    Thanks. Yesterday, I got it works by changing the license from FLOAT to FIX.
    Now, I'm be able to program my sof file, but I have other problem on C2H side. When I try to run my program on C2H, I get this errors.
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00.
    Pausing target processor: not responding.
    Resetting and trying again: FAILED.
    Leaving target processor paused
    I thought I have a C2H full license too.
