15 years ago --- Quote Start --- Thanks. I have a vendor FAE takes a look at it. The errors. Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2 Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCE1 Info: SRAM Object File E:/Work/DemoA/DemoA_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCEC --- Quote End --- Hi, it looks like that you use an IP block which is not covert with the subscription licence. Have a look to your design and find out which IP's you are using and compared it with the IP's which are included, Kind regards GPK
