HongLiang
3 years agoError(129015): Output port PAR_OUT on atom "lvds_rx_sp|u0_single|lvds_0|core|arch_inst|rx_channels[2
we dont know what happen in agliex-F device to use the LVDS RX IP
Quartus pro 22.4
if we export the LVDS RX IP parallel date to IO this error will disappear.
WZ2
3 years agoHi there,
Any update~
anonimcs
Contributor
1 year agoHi@WZ2 and @HongLiang ,
I'm having a similar compile error on Quartus Pro 21.3 for my project in Cyclone 10. I've set the number of channels to 24 and the serdes factor to 7 in the LVDS IP, but I'm getting the error message below and couldn't figure out why. The message says that the output port is disconnected, but I connected that to another component in the Platform Designer... If you already know the solution, I'd be very appreciated when you share it with me!
Cheers
Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[7].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[7].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[1].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[1].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[6].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[6].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[15].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[15].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[3].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[3].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[2].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[2].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[5].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[5].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[4].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[4].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[13].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[13].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[14].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[14].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[16].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[16].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[12].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[12].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[10].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[10].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[11].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[11].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[9].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[9].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[8].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[8].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[23].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[23].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[22].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[22].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[17].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[17].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[18].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[18].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[19].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[19].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[20].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[20].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[21].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[21].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[0].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[0].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port. Error: Failed to synthesize partition
