15 years ago
Error
I have some problems when I try to compile mymux. This is my code:
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
Entity mymux21 is
port (A,B: in std_logic_vector (3 downto 0);
S: in std_logic;
F: out std_logic_vector (3 downto 0));
end mymux21;
Architecture behave of mymux21 is
begin
F <= A when (S = '0') else B;
end behave;
Architecture struct of mymux21 is
component mymux21 is
port (A,B,S: in std_logic;
F: out std_logic);
end component;
begin
Copy1: mymux21 port map (A => A(0), B => B(0), S => S, F => F(0));
Copy2: mymux21 port map (A => A(1), B => B(1), S => S, F => F(1));
Copy3: mymux21 port map (A => A(2), B => B(2), S => S, F => F(2));
Copy4: mymux21 port map (A => A(3), B => B(3), S => S, F => F(3));
end struct;
and the error is: "project too complex: hierarchy path is too long"
    --- Quote Start ---
    oh, what is error? and how can I correct it?
    --- Quote End ---
    The error is your project is too complex and the heirarchy is too large. I assume you have layers and layers of code. To fix it - have less layers
    The problem could be the code. You are creating an architecture that instantiates itself, possibly creating an infinite loop. You should use different names for the std_logic and std_logic_vector versions of your mux.
  • Juan_Miller's avatar
    Juan_Miller
    I suggest you try Long path tool is the very good program for easily delete, copy & rename long path files, error, unlock solution.
    Try it and solve your problem.
