17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
17 years agoI had the same problem when I first started a while back. The solution I found that allowed Quartus II to compile my Verilog files was:
1)File | New | Block Diagram/Schematic File with the same name as Project 2)Click on the HDL source files (*.v etc) (it must be the active window) 3)File | Create/Update | Create Symbol File for Current File 4)Double click on the ProjectName.BDF file you created in Step 1 and insert your new Symbols from you made in step 3 5)Double click on the ProjectName.BDF file you created in Step 1 and insert pin assignments (Inputs, Outputs, etc) Now Quartus II allowed my verilog modules to compile. Cheers
