17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
17 years ago --- Quote Start --- hello, I met with the same question, --- Quote End --- As FvM indicated this error message is caused by the fact that no VHDL entity is found with the name of the "top level entity". It is not enough to name your VHDL file with the name of the top entity. The top entity itself of your VHDL description should have this name. e.g. In the example below TOP is the "Top Level Entity" and has been declare d like that (see @pletz) file TOP.vhd entity TOP is port ( ... ); end TOP; architecture my_design of TOP is begin ... end my_design;
