slolson
1 year agoError: spi_0: Failed to find module spi_spi_0
I am trying to generate the SPI (4 Wire Serial) Intel FPGA IP core, but the platform designer fails to generate the HDL. It looks like it could be due to "Info: spi_0: Illegal division by zero at /to...
- 1 year ago
Please don't export the clock and reset ports then connect those ports to the clock source.
regards,
Sheng
ShengN_altera
1 year agoHi,
Could you double click the IP to see any error settings configuration?
If got error, it'll not be generated.
Sheng
- slolson1 year ago
Yes, no errors after configuration before generating HDL.
