Error licence to Questa on Quartus 24.1 lite
when using waveform in windows version of quartus lite, I got the error:
**** Running ModelSim simulation ****
c:/intelfpga_lite/24.1std/questa_fse/win64//vsim -c -do TopDE.do
** Fatal: Failed to initialize licensing environment. License environment not set correctly.
Unable to verify a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
Error.
I have seen similar errors in older versions on the forums, but these solutions did not work.
I even tried to install the licence driver and downlod the licence to questa, puting it on the path as LM_LICENSE_FILE as the quick start says, nothing worked.
- RichardT_altera
Could you invoke the standalone Questa FPGA Starter Edition software?
Are you using a node-locked or floating type license? Could you share the license file .dat ?
Richard Tan - lucas22
Could you invoke the standalone Questa FPGA Starter Edition software? No
Could you share the license file .dat ? Ok at the atachments
- RichardT_altera
Do you observe any license checkout error message when invoke the Questa?
The license file seems fine. *Make sure the NIC ID is correct.
Do you set any other variable like MGLS_LICENSE_FILE or SALT_LICENSE_FILE?
Those variables take precedence over the LM_LICENSE_FILE.
If so, you may keep LM_LICENSE_FILE while ensure the others are deleted. Or you may set all variable to the license path.
*Make sure the license path is valid and exist.
Richard Tan
- RichardT_altera
Any further update on this?
Do you able to resolve the issue?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Richard Tan
