lucas22
1 year agoError licence to Questa on Quartus 24.1 lite
when using waveform in windows version of quartus lite, I got the error: **** Running ModelSim simulation **** c:/intelfpga_lite/24.1std/questa_fse/win64//vsim -c -do TopDE.do ** Fatal: Failed to ...
lucas22
1 year agoCould you invoke the standalone Questa FPGA Starter Edition software? No
Could you share the license file .dat ? Ok at the atachments
- RichardT_altera1 year ago
Do you observe any license checkout error message when invoke the Questa?
The license file seems fine. *Make sure the NIC ID is correct.
Do you set any other variable like MGLS_LICENSE_FILE or SALT_LICENSE_FILE?
Those variables take precedence over the LM_LICENSE_FILE.
If so, you may keep LM_LICENSE_FILE while ensure the others are deleted. Or you may set all variable to the license path.
*Make sure the license path is valid and exist.
Richard Tan
