15 years agoError during CPLD gate-level sim
I am running gate-level sim of a design, written in Verilog for a MAX3000A CPLD and I am getting errors. Does anyone know what is going on? What issue is the error indicating? Attaching the ModelSim transcript.
Thanks, Tony ModelSim transcript: # Loading instances from spisram_v.sdo # Loading timing data from spisram_v.sdo # ** Note: (vsim-3587) SDF Backannotation Successfully Completed. # Time: 0 ps Iteration: 0 Region: /spisram_tb File: Z:/sram_clpd/altera/spisram_tb.v # WARNING: No extended dataflow license exists # # add wave * # view structure # .main_pane.structure.interior.cs.body.struct # view signals # .main_pane.objects.interior.cs.body.tree # run -all # 0 << Starting the Simulation >> # 0 addr=0000000000000000000, data=xxxxxxxx, ctrl=01, sclk=0, ss=1, mosi=0, miso=x # 1 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=1, mosi=0, miso=z # 20 << Single Write Test >> # 20 << Slave Select >> # 21 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 22 << Driving byte: 07 >> # 23 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z # 25 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 27 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z # 29 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 31 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z # 33 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 35 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z # 37 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 39 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=0, miso=z # 41 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=0, miso=z # 42 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z # 43 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z # 45 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z # ** Error: C:/altera/11.0/modelsim_ase/win32aloem/../altera/verilog/src/max_atoms.v(2128): $setup( datain:44500 ps, posedge pclk[0] &&& reset:45200 ps, 1300 ps ); # Time: 45200 ps Iteration: 2 Instance: /spisram_tb/U1/\data0[5] /preg # 47 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z # 49 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z # 51 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=1, ss=0, mosi=1, miso=z # 53 addr=0000000000000000000, data=zzzzzzzz, ctrl=01, sclk=0, ss=0, mosi=1, miso=z
