18 years ago
Error during compilation when using 'Process'
I have written a code that can compile when not using Process but gave error during compilation when process is used.
I am not sure how to solve it. The stucture of the code is similar to the one I got from a book.
Here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
Entity Adder4 is
    port( C     : in std_logic;
          X, Y, clock    : in std_logic_vector (1 downto 0);
          R        : out std_logic_vector (2 downto 0));
end Adder4;
Architecture Version1 of Adder4 is
    signal Carry : std_logic;
    component FullAdd3_B
    port (    A, B, Cin, clk        :     in std_logic;
               Sum, Cout    :    out std_logic);
    end component;
begin
Process (clock)
    begin
            UO1:     FullAdd3_B PORT MAP (X(0), Y(0), C, clock(0), R(0),  Carry);
            UO2:     FullAdd3_B PORT MAP (X(1), Y(1), Carry, clock(1), R(2), R(1));
    end process;
end Version1;
Here are the error messages:
Error (10500): VHDL syntax error at Adder4.vhd(21) near text "PORT";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Adder4.vhd(21) near text ";";  expecting ":=", or "<="
Error (10500): VHDL syntax error at Adder4.vhd(22) near text "PORT";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Adder4.vhd(22) near text ";";  expecting ":=", or "<="
Pls double check to see if I have missed anything. I cannot spot any error. I just don't understand why the code can work without using process but refuse to cimpile when using it.
Thanks..
    Instantiating components as modules in your design is not done inside of a process.
    Also, and this is purely personal, using positional notation for the signal declarations in your module instantiations is a monstrously evil thing that should be avoided like the plague.
    BR
    --- Quote Start ---
    --- Quote End ---
    How should I instantiate components?
    --- Quote Start ---
    --- Quote End ---
    Sorry., I don't quite understand what you mean.. I'm only a few weeks into the world of VHDL so I am still not very familiar with the do's, don'ts and how to's of VHDL..
    Can you please explain more or maybe show some sample coding of how i should do it..?
    Thanks..
    I have re-written your code snippet to try to show you what I mean.
    I have not checked it so please forgive any typos.
    library IEEE;
    Entity Adder4 is
    end Adder4;
    end component;
    begin
    --- Instantiating modules is not done inside of a process
    --- All I did was strip away the process statements
    --- around your 2 instantiations of component FullAdd3_B
    --- in the below example the signals in the
    --- top level design are associated with
    --- the signals in the component through
    --- named association or explicit association
    --- not by position
    --- in this case the position is the same as
    --- your component declaration, but it does
    --- not have to be
    UO1: FullAdd3_B PORT MAP (A => X(0),
    B => Y(0),
    Cin => C,
    clk => clock(0),
    Sum => R(0),
    Cout => Carry);
    --- in the instantiation below
    --- which I have left as you had it
    --- you are creating the association
    --- between signals by way of the position
    --- of the signals in the declaration
    --- both methods are allowed
    --- I just like the former as it
    --- keeps me from stepping on my
    --- own toes which I do enough
    --- without even trying
    end Version1;
    I understand now.. Thanks..
    Yeah, I prefer your way of using instantiation..
    by the way, instead of instantiating like this
                                                              B => Y(0),
                                                              Cin => C,
                                                              clk => clock(0),
                                                               Sum => R(0),
                                                               Cout => Carry);
    If I accidentally reverse the sequence, for example as below
        Sum => R(0),
                                                               clk => clock(0),
    Cin => C,
    B => Y(0),
    Cout => Carry);
    will it still work..?
    By the way, just to confirm.. Is "A <= B" in VHDL is same as "B => A"..? I've only used "<=" before.
    You should have some minimum literature at hand, that shows the VHDL syntax. You can learn it e. g. from VHDL templates in Quartus editor. But I think, you may consult a detailed textbook.
    Apart from better readability, one adavantage of named notation for component instantiation is, that the argument order can be changed. For this reason, both variants are equivalent.
    The '=>' operator meaning is completely different from '<='. It's used for named notation in component instantiation and aggregates or for selection in case statements. See my first remark.
