Error: Can't Launch Questa Intel Starter FPGA Edition from Quartus Prime Pro tool.
- 3 years ago
Hi Sohan,
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683472/22-1/and-software-license.html and this link https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/mapIdTopics/jka1465598270294.htm
Specifying the following commands below in .cshrc or .bashrc file (Linux):
export LM_LICENSE_FILE=<path to license>:$LM_LICENSE_FILE
setenv LM_LICENSE_FILE "<path_to_license_file>"
Note: Linux: You must source your .cshrc (source ~/.cshrc) or .bashrc (source ~/.bashrc) file before restarting the software.
Sheng
Hi Sohan,
Sheng
- SohanHPatel3 years ago
Yes these things have solved the license error. but then only simulator library is getting compiling for long time. Simulator is not getting open. How can I open Simulator in quartus prime pro edition.
Right now I am following these steps.
1. Open Project.
2. Tools -> Launch Simulator Compilier Library -> then setting execuatable location path and compiling it.
Am I following right method or is there any other way to launch the compilier? (As in Lite edition, there is separate menu for Run Simulation likewisw).
Sohan
