UserID4331231
1 year agoError: avalon_slave: Agent with readdatavalid signal must support at least 1 pending read
while making a custome IP component with AVMM slave port I am running into this error in platform designer Error: avalon_slave: Agent with readdatavalid signal must support at least 1 pending read ...
- 1 year ago
I was able to add the "maximumPendingReadTransactions " parameter. its just that how Platform designer gui is created, it made hard to figure out that you can "scroll" to right to see properties column.
UserID4331231
1 year agoHi Kenny
the quartus tool is in our EC machines and screenshots are disabled for security and IP compliance policies. I wont be able to share screenshot. Here are some feedback which may help you with what you may be looking for.
- i created my custom IP in platform designed using "new component" on top left of the gui
- i added AVMM Memory agent port and signal to my design. I saved and close the component.
- I used this component in my platform designer gui and made connections as desired.
- I tried to do generated HDL and it failed with the error i reported.
- from error I could figure out that it has to do with AVMM agent port and missing parameter.
- in Platform designer i clicked on my component , on right top corner of the window , i chose component instantiation.
- Now here on top right area of Platform Architect Gui, I felt that things are cramped here and and because of GUI theme colors (same shade of grey) i think i missed a thin horizontal bar initially, which would indicate that there things to your right.
- Once I (accidently) figured that out i was able to see all parameters field there.
i hope this helps
KennyT_altera
1 year agoI tried your steps but I do not see the error, I attached the project here. Can you help me to modify it?
