UserID4331231
1 year agoError: avalon_slave: Agent with readdatavalid signal must support at least 1 pending read
while making a custome IP component with AVMM slave port I am running into this error in platform designer Error: avalon_slave: Agent with readdatavalid signal must support at least 1 pending read ...
- 1 year ago
I was able to add the "maximumPendingReadTransactions " parameter. its just that how Platform designer gui is created, it made hard to figure out that you can "scroll" to right to see properties column.
UserID4331231
1 year agoI was able to add the "maximumPendingReadTransactions " parameter. its just that how Platform designer gui is created, it made hard to figure out that you can "scroll" to right to see properties column.
