danield17
1 year agoError 23098 when compiling Agilex5 GTS PCIe
I tried to create a design with PCIe GTS IP core and SSGDMA on Agilex5 but I got the following error: One or more blocks are configured incorrectly and will not have the desired functionality. -...
Wincent_Altera
1 year agoHi,
May I know which Quartus version that you are using ?
Can you please regenerate the same design in Quartus v24.3 onwards and see if you are still able to see the same error ?
Based on my experience these errors are caused by an invalid combination of reference clock frequency and operating bit rate.
It happened in Quartus v24.1 and v24.2..
These combinations had removed in Quartus® Prime Pro Edition Software v24.3 onwards.
By right it shall work well when you try v24.3.
Wincent_Altera
danield17
1 year agoHi,
I am using Quartus v24.3.
I have currently selected PCIe gen4 x4 with 256-bit interface and a reference clock of 350MHz.
Hopefully, this information helps in understanding the issue.
danield17
danield17
- Wincent_Altera1 year ago
Hi Daniel,
May I know what is the device OPN that you are using for the gen4 design ?
FYI, "5S /6S" device does not support gen4 . if you are using those OPN , the error is expected.
You can use "4S" OPN for gen4
Wincent_Altera
