8 years agoEfficiency improvements after switching to 17.1 from 17.0
Just as an FYI: I noticed significant resource savings on the same code when switching to version 17,1 of the tool from version 17.0. I'm not sure if this is common for new releases of this tool but thought I should mention it. If you're getting tight on resources it may be worthwhile to install 17.1 alongside whatever version you're using and try it out. (Note: don't forget to use a BSP that supports 17.1).
