8 years agoEfficiency improvements after switching to 17.1 from 17.0
Just as an FYI: I noticed significant resource savings on the same code when switching to version 17,1 of the tool from version 17.0. I'm not sure if this is common for new releases of this tool but...
8 years ago --- Quote Start --- If you have a "top.done" then everything should be fine and configuration should happen through PCI-E. You are using Arria 10, right? What is your board? --- Quote End --- Arria 10 GX
