8 years agoEfficiency improvements after switching to 17.1 from 17.0
Just as an FYI: I noticed significant resource savings on the same code when switching to version 17,1 of the tool from version 17.0. I'm not sure if this is common for new releases of this tool but...
8 years ago --- Quote Start --- Hi guys, A bit of topic but I need some help: I recently updated to 17.1 from 17.0, and now the configuration is using JTAG instead of PR via PCIe. Can't find documentation about this in the update, and "ACL_PCIE_USE_JTAG_PROGRAMMING=0" doesn't work. Anyone know what's going on? Configuration via JTAG is so much slower than PCIe... --- Quote End --- Check the project folder that the OpenCL compiler creates and see if you have a "top.done" file in it or a "flat.done" file. There was another thread in the forum before that seemed to suggest that people are being defaulted to the flat flow in v17.0. If you compile with the flat flow, reconfiguration can only be done using JTAG.
