matferronato
2 years agoEarly timing analysis + Intel's IP
Hello, I updated Quartus Prime Pro to version 23.4, which gives me access to the Early Timing Analysis using RTL-on-SDC files. The majorities of my clocks are defined by the sdc files automatically...
TingJiangT_Intel
Contributor
2 years agoSure, I want to confirm if the issue won't occur after full compilation with all IPs added to the project (After Fitter and Router Finishing) to locate if the issue is caused by early timing or other issues.
